Greyed out tolerance from inheritance feature
How do I add tolerance to a dimension from an inheritance feature?
Tolerance in the model is set to symmetry but after inheritance the Tolerance is at Nominal and can not be changed (greyed out)
rbray-21-VisitorAuthor
The only way I've found is to open the base model and change it there.
Dale_Rosema
See if this thread helps:
Re: Changing Dimension Tolerance Mode - PTC Community
Thanks, Dale
Emeritus
@Dale_Rosema
The link you posted seems to be broken. Could you please check if its correct?
