Hello, can use some help trying to set Plus-Minus tolerance on a dimension
  • June 19, 2017
  • 8 replies
  • 3284 views
dimension tolerance upper and lower states +0.001 -0.001 doesn't match drawing dimension +1 -1 not sure what to do, can somebody explain please, missing dimension decimal places!
Do you mean the model shows the upper /lower limits as +0.001/-0.001 and the drawing is showing +0.1/-0.1?
What version of Creo are you using? The dialog changes with different versions.
Show pictures would help.
kmellace1-VisitorAuthor
Hi Ben,
Creo 3, the dimension on model is 1.50 and drawing 1.50
on the Dimension Properties under Tolerance mode to Plus-Mins upper .0000 lower +0.005 what I end up is dimension on drawing 1.50 +.00 -5.00
StephenW
And is the drawing dimension created? Maybe you are referring to a model dimension you've set with the correct tolerance and a created drawing dimension that is showing a different tolerance?
It ended up files got deleted in Creo 3 and didn't allow tolerances to be modified, I was told by PDM Admin. ???
StephenW
Well that sounds really strange??!!
