Help!!!
  • February 22, 2017
  • 6 replies
  • 2860 views
Hi all, I have developed a catastrophic problem with Creo 3 this morning. Everything was fine until a couple of hours ago, now I cannot open ANY drawing. I can open parts & assemblies no problem. At first I thought it was just a problem with the job I am currently working on, I had a couple of crashes this morning & I figured that maybe some files had become corrupted somehow. I have done some investigating & discovered that this problem exists outside my current working directory. There is nothing wrong with any of these files, I can open them fine in Creo 2 & 4. I can open my current drawings in Creo 4, so that proves the files are ok. 20 years I have been working with Pro-e/Creo & have never seen this before. As mentioned, I have Creo 4 installed but I don't want to start working with it just yet. Any clues any one? I am in a fix here, don't whether to un-install Creo 3 & re-installed it.
Regards
John
Best answer by John.Pryal
We just figured this out, it was the creo_parametric_customization.ui file causing the problem. I installed Creo 4 the week before last. I have both versions start from different load points & have a customization.ui file in each. What I did not realize is that Creo does not pull in the ui file from the load point directory unless you tell it to. There is a config option load_ui_customization_run_dir which needs to be set to 'yes'. This morning while working in Creo 3 i made a change to the ui, & a conflict of sorts was created. All ok now, but 3 hours lost trying to figure this out. Thanks for your time.
John
Chris3
My guess is that you changed the order of your seats in your parametric.psf file.
check <load point>\Creo 3.0\MXXX\Parametric\bin\parametric.psf
for this line:
ENV=CREOPMA_FEATURE_NAME=
Compare that to your psf file for your other installations.
Good idea with the license.  Other things to think about, maybe a corrupted ui customization file?  If it is crashing in Creo 3 (as opposed to saying 'failed because reasons'), you could attach a traceback.log.zip and I could see if the traceback analysis tool has anything useful to say.  Conversely, if it puts up a failure message, that could be useful.
have you rebooted your workstation after the Creo crashes? You could have some traces of memory being misallocated.
John.Pryal1-VisitorAuthorAnswer
John
Dale_Rosema
Glad you were able to figure it out.
Do forget to mark your answer as correct.
