Help creating a graph from an evaluation
Hi folks
I'm hoping someone can help me find a way to create a graph from a flexible evaluation feature. Let me explain a bit more.
I have an evaluation feature that is built by moving a point along a curve. I need to be able to create a graph that shows the value of the point on one axis and the value of the evaluation on the other. It seems easy, but I've run out of ideas on the actual implementation.
Any of you smart people have an idea?
Troy Ashby
