Help Required in Dealing with Excel Analysis Features
I have a generic parametric model in Creo. Part dimensions are controlled by excel sheet using excel analysis feature. When I update the excel file, and I regerate the model, the updated values are not reflected in model. I have to first right click on excel analysis feature and click "edit definition" and then regenerate. Is there a way where these two steps can be reduced to one or is some programming possible to automate these two steps using some UI ? Or is there any bettter way to control the model from excel other than "excel analysis" tool ?
Any help is highly appreciated !!
