Hidden line hide & show?
  • July 4, 2012
  • 2 replies
  • 16545 views
Hi all,
I'm working on a drawing and I need to show a view with hidden lines but I don't want to show all of them as this will make the view look too cluttered. Is there a way to hide/unhide hidden lines on drawing views?
Many thanks for any help,
Rob K
Best answer by LukaszMazur
There is. Use "Edge Display" command from Layout tab (if you're working in Creo Parametric) and erase lines you don't wan't to show. If you'd like to display them back, set display style to default and select them again (may be a bit tricky with non-visible lines, box-select region with hidden edges should do the job).
And if you're working on WF4 or older, the same command is located under View > Drawing Display > Edge Display.
That did the trick many thanks.
Rob
