Hole Table for Cutouts
  • July 30, 2019
  • 4 replies
  • 1958 views
I am detailing parts where all the holes were created as cutouts and am finding this to be impossible to accomplish.  I have selected the "cutouts" option in the Hole Table window, but when I'm prompted to select a coordinate system I get the message that the Z direction is incorrect...or something to that effect.  I tried to modify the CCYS, or create a new one to no effect.  I will also say that the parts I'm trying to create a hole pattern for have been flattened via a Family Table, however that shouldn't matter as I made a test file using the Hole command and all went well.
please can you upload model for testing purposes ?
Mahesh_Sharma
22-Sapphire I
July 31, 2019
@bowsmoke
If cutouts are selected, it will include holes created using extrude cut. But if you are getting error about Z direction, try creating a csys which will have Z parallel to hole axis and use that on hole creation. or as @MartinHanak  suggested share the part for review..
bowsmoke1-VisitorAuthor
Just figured out that the Hole Table will not work on "imported" geometry.
Mahesh_Sharma
22-Sapphire I
August 1, 2019
@bowsmoke
For imported geometry, you can create Hole table. But for that hole/cuts in imported geometry needs to be recognized as hole.  You can use Feature Recognition tool for such holes, depending on geometry.
Feature Recognition tool can enabled by setting config frt_enabled as yes. further details are in
CS28594
and http://support.ptc.com/help/archive/creo30/creo_pma/usascii/index.html#page/part_modeling%2Ffeature_recognition_tool%2FTo_Create_Hole_Feat_from_Imported_Geom.html%23
