How can I add a layer to a "harness" part.
  • August 4, 2015
  • 2 replies
  • 1141 views
The "harness" part (in cabling) can not be opened independently. It can only be opened in the harness assembly which includes the connectors etc.
I seem to be unable to add a layer to this part. Does anyone know of a solution?
Vince,
is it possible to Activate harness part in Assembly mode ?
Martin Hanak
I haven't tried to activate the harness part in assembly but I'll give that a try.
I have semi-successfully managed to add the layers.
The obvious problem is that the harness part can not be opened by itself. so the usual layer functionality is not available.
I have stumbled onto a goofy work-around where I select the feature (plane in this case) to add it to the layers of ANOTHER component.
THEN I get the little window where I can add the layer to the harness part.
I really hope to have the harness start part include all the layers next time.
