How can I control pipe branch cuts?
  • March 30, 2015
  • 3 replies
  • 1953 views
By default, piping tool seems cut intersection point based on the inner diameter of the pipe segment. I would like to change this default to outer diameter which matches the way my manufacturing shop constructs tees and saddle joints. Is there a way to change this default?
2-Explorer
April 2, 2015
Maybe a little schematic picture will help better understanding what you currently see and how you would like it to be instead?
(still no guarantee for a helpful answer, but another chance)
smurphy1-VisitorAuthor
Gunter,
I hope these images help. The top one is what I want to do in pro pipe. The bottom one is what I generated in pro pipe. The bottom one saddles the ID and I want to saddle the OD.
I also have these too. Top one is the OD saddle and the bottom one is the ID saddle.
