How can I format representing a dimension in a note as an absolute value if the value is negative?
  • May 15, 2017
  • 2 replies
  • 1394 views
Hello All,
How can I format the text in a note or table that represents a parametric dimension, as an absolute value, if the value is negative?
Jeff
2-Explorer
May 15, 2017
At worst, create a separate parameter that is set, by relation, to the absolute value of the dimension.
I will do.  Thanks a lot for the response.
