How do I route individual cores of a predefined cable to mutiple devices?
I have a 8 cond groupshape whos cores/conductors goes from 8 seperate instances of the the same blockshape and terminate in freespace.
It works fine going from connector to connector. By that I mean if I route each end to the first port on a 8pos connector the other seven populate automatically. But how do I route each conductor indivdually like here.
Here is the message i get after placing the first conductor:
- Start the fiber by probing on a port or branch, or use the shortcut menu to start in free space
- Choose a port or highway to terminate. Probe in free space to route, or use the shortcut menu for additional options.
- Not enough ports to connect all cores
- 7 cores not routed
