How to add letter/mark/symbol for 2D dimension properities continuous
  • September 1, 2017
  • 6 replies
  • 2761 views
For example, I already set up Mapkey "AA" to add symbol " * " prefix to the dimension.
And Mapkey "AB" to add letter " CP " prefix to the dimension.
Plan to get the result " CP * Dimension " by press "AA" then "AB"
or " * CL Dimension " by press "AB" then "AA"
But it will be covered by latter one.(Only " * Dimension " or " CP Dimension ")
How could I add letter/symbol continuous both prefix and suffix?
Thanks.
20-Turquoise
September 1, 2017
Thanks.
I am not sure I understand exactly what you are wanting here however you can create a new mapkey that uses existing mapkeys like this:
mapkey c %AA;%AB;
mapkey d %AB;%AA;
Note the syntax is %<MapKey>;
Hi  Jones,
I try your approach but first one will be covered by later one.
Like photo below, photo 3 is what I want.
Every time the first one will be covered by later one.
I can't get *+CL in one mapkey (The approach you suggest) or two map key.
Do you have any other suggestion? Thanks.
 Mapkey: AAMapkey: AAMapkey: ABMapkey: AB
What I wantWhat I want
mapkey c %AA;%AB;
mapkey d %AB;%AA;
2-Explorer
September 10, 2017
Please post the Mapkeys you have written and the version of Creo you are using.
Make a 3rd mapkey that does both prefix and suffix.
