how to add weight column in BOM
  • August 20, 2015
  • 3 replies
  • 4014 views
procedure
please provide more details. For example:
Do you use Bill of Material command in Assembly mode ?
-OR-
Do you use Repeat region table in Drawing mode ?
Martin Hanak
kb-31-VisitorAuthor
is there any bill of material option in creo
i used repeat region
i need to create a weight parameter in part and i have to call back by asm-mbr-parameter-weight
if any easiest matter apart from these tell me and thanks for your reply
look into Re: how to develop a relation for calculating the mass of part in BOM discussion - PRO_MP_MASS system parameter.
Martin Hanak
