HOW TO AUTOMATE UDF REFERENCE SELECTION USING VB.API
  • January 23, 2017
  • 2 replies
  • 2157 views
Hello All,
     I have created a VB.API program for the customization of an assembly. In this i have used a UDF to create a set of Co-ordinate system which is driven through excel. But the problem what i am facing here is when the  Co-ordinate get created using the UDF each time i have to manually choose the Reference Co-ordinate system.  How can i make that a single selection process.
Below i am giving the codes, Please guide on this.
  Public Function createHoleUDFInPart(ByVal placementModel As IpfcSolid, _
                                        ByVal Name01 As String, _
                                        ByVal csysName As String, _
                                        ByVal Dim1 As Double, _
                                        ByVal Dim2 As Double, _
                                        ByVal Dim3 As Double, _
                                        ByVal Dim4 As Double, _
                                        ByVal Dim5 As Double, _
                                        ByVal Dim6 As Double, _
                                        ByVal aseemblycount As Integer) _
                                        As IpfcFeatureGroup
        Dim csys As IpfcCoordSystem = Nothing
        Dim cSystems As IpfcModelItems
        Dim i As Integer
        Dim udfInstructions As IpfcUDFCustomCreateInstructions
        Dim csysSelection As IpfcSelection
        Dim csysReference As IpfcUDFReference
        Dim references As CpfcUDFReferences
        Dim variantDims As IpfcUDFVariantDimension
        Dim variantDims2 As IpfcUDFVariantDimension
        Dim variantDims3 As IpfcUDFVariantDimension
        Dim variantDims4 As IpfcUDFVariantDimension
        Dim variantDims5 As IpfcUDFVariantDimension
        Dim variantDims6 As IpfcUDFVariantDimension
        Dim Coname As String
        Dim variantVals As IpfcUDFVariantValues
        Dim group As IpfcFeatureGroup
        Try
            cSystems = placementModel.ListItems(EpfcModelItemType.EpfcITEM_COORD_SYS)
            Coname = "ACS" + Convert.ToString(aseemblycount)
            For i = 0 To cSystems.Count - 1
                If (cSystems.Item(i).GetName.ToString = "ASM_CSYS") Then
                    csysName = "ASM_CSYS"
                    csys = cSystems.Item(i)
                    Exit For
                End If
            Next
            If csys Is Nothing Then
                Throw New Exception("Coordinate System not found in current Solid")
            End If
            udfInstructions = (New CCpfcUDFCustomCreateInstructions).Create("CSYS")
            udfInstructions.DimDisplayType = EpfcUDFDimensionDisplayType.EpfcUDFDISPLAY_BLANK
            csysSelection = (New CMpfcSelect).CreateModelItemSelection(csys, Nothing)
            csysReference = (New CCpfcUDFReference).Create("Reference Coordinate System", csysSelection)
            references = New CpfcUDFReferences
            references.Set(0, csysReference)
            udfInstructions.References = references
            variantDims = (New CCpfcUDFVariantDimension).Create("d0", Dim1)
            variantDims2 = (New CCpfcUDFVariantDimension).Create("d1", Dim2)
            variantDims3 = (New CCpfcUDFVariantDimension).Create("d2", Dim3)
            variantDims4 = (New CCpfcUDFVariantDimension).Create("d3", Dim4)
            variantDims5 = (New CCpfcUDFVariantDimension).Create("d4", Dim5)
            variantDims6 = (New CCpfcUDFVariantDimension).Create("d5", Dim6)
            variantVals = New CpfcUDFVariantValues
            variantVals.Set(0, variantDims)
            variantVals.Set(1, variantDims2)
            variantVals.Set(2, variantDims3)
            variantVals.Set(3, variantDims4)
            variantVals.Set(4, variantDims5)
            variantVals.Set(5, variantDims6)
            udfInstructions.VariantValues = variantVals
            references.GetHashCode()
            group = placementModel.CreateUDFGroup(udfInstructions)
            Return group
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
            Return Nothing
        End Try
    End Function
End Class
I am also trying to automate the placement of udf features. The problem is that I still have to select the references in the model even though I am passing them in as CpfcUDFReferences. Is there a proper example of how this works so the user does not have to select the references? Or is there a settting that needs to be triggered?
Thanks!
I believe I have found the solution to this problem. After the CreateModelItemSelection line I added a line highlighting the selection.
csysSelection = (New CMpfcSelect).CreateModelItemSelection(csys, Nothing) 'Existing line
csysSelection.Highlight(EpfcStdColor.EpfcCOLOR_SELECTED) 'Added line
