How to change interface-to-interface to interface-to-geom.
  • May 30, 2019
  • 2 replies
  • 1846 views
We have some very large assemblies. When we add fasteners to the top level assembly, it takes literally minutes to load due to all of the interfaces. Is there a way to change the mating default to interface to geometry?
Set configuration option "comp_interface_placement interface_to_geom".
StephenW
I believe I set the following in the config.pro
comp_assemble_with_interface NONE
comp_interface_placement INTERFACE_TO_GEOM
I had the same problem with large assemblies and it was a major time waster.
