How to Clear CREO 2.0 Parameter Names
  • September 6, 2014
  • 16 replies
  • 5397 views
I used parameter names (tools/parameters) to set up the model to be parametric with ANSYS Workbench. I am creating a new model and want to use the same parameter names as another model. I started a new session of CREO 2.0, created a new part, named the dimensions and then when I tried to create the parameter, I got a message that the Parameter name was already in session.
How do you clear parameter names? The old names do not show up in the Parameter List.
Best answer by TomD.inPDX
I am going to suggest this is a version issue.
In this file you already changed the dim symbol to insert_id
and you created the unitless parameter ds_insert_od.
I open relation and add insert_od=ds_insert_od and check the relations.
I get a successful message.
Do you have maintenance? Again, I think this is a known issue but if you can, report it.
Video Link : 5265
Randy,
can you upload your model and provide parameter name, you want to create ?
Martin Hanak
I emailed the file to you. I do not see an attachment icon in this window.
You can attach files using the advanced editor... upper right corner of the reply UI.
