How to convert imported iges(surface) file to solid part?
I have a problem, I imported a iges model file, now it is in surface, how to convert surface model into solid model in Creo 3.0?
If it is not automatically solid then it probably has gaps or missing surfaces. You have to use either IDD or possibly adding surfaces to make it solid (plus possibly a combination of changing accuracy and other tricks). This can range from a few seconds to a few hours depending on how bad the import looks.
The very first hing you can try is select it and hit Solidify and see if that does it.
No account yet? Create an account
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
