How to create a boundary blend at a distance from a surface?
  • May 6, 2015
  • 9 replies
  • 2950 views
Hello all...I want to create a boundary blend or a curved plane at a distance from a surface parallel to it, so that i can extrude a certain profile up to that plane but I cant find a way how to do it..please help me out there. I am using PTC CREO 2.0
The Offset function is what you're looking for.
Change your selection filter to Geometry:
Select the surface you want to offset:
Pick Offset (Model tab, Editing group):
If it's not too complex of a surface, you get an offset at the distance entered:
If you want side surfaces, that is available in the Options tab:
simran1-VisitorAuthor
Thanks for helping Sir but i actually tried that and still its not extruding upto that surface. It only lets me select the original surface geometry for extrusion and not the offset one.
The part I outlined only creates surfaces. It may require some additional boundary blends, merges and a solidify.
Without seeing the piece you're having trouble with, I may be out of suggestions.
Would simply using offset from flexibile modeling tab do it for you?
