How to create a jogged cross section
  • August 7, 2013
  • 4 replies
  • 7877 views
I have a part that I would like to cross section like the sketch. The radial holes are at an angle and I would like to show how the angle relates to the countersunk holes in the cross section, so the part is made correctly. How do I do this? I'm fairly new at Creo. I am using Creo Elements/Pro 5.0.
Best answer by TomD.inPDX
This is an offset section. You simple create an open sketch that will be the cut. You will have other options when you place the view, such as unfold.
You might go through the help files. The help files to actually show all the different types of sections that are supported and also show how to use them.
Welcome to the forum.
K.Wygant1-VisitorAuthor
Thank you Antonius. I was a Solid Works user and am new to Creo. So, I am not used to all the references that are needed. Also, It is difficult to use the Creo help when you don't know what you are looking for! I typed in cross section, but didn't know it was called offset cross section.
I did get the section to work. It show up correctly in the model, but I am only getting 1/2 of the cross section to show in the drawing. The other half is not cross sectioned. Is there a setting somewhere that I am missing.
