How to create symbol that will auto-increment?
  • May 2, 2012
  • 3 replies
  • 2492 views
In a drawing with many dimensions, I have a need to add a reference number for each dimension on the drawing. (1,2,3......) And each number needs to be in a circle similar to a BOM balloon. Since there are so many, I would like to be able to create something like a custom symbol that would auto increment the number each time I clicked a new location with the mouse. Then if I went back later to add more, it would increment based on the highest reference number already on the drawing.
Is this possible?
Looking for this as well, have found ZERO answers.
Did you ever get this to work?
Best, Nick
I think this isn't built in. J-link or WebLink could work; it would be tough to do with a complex mapkey. If pressed I would work it with AutoIt, but the performance might be sluggish - each iteration would include retrieving a parameter value (the last highest number), create the symbol, then update the parameter value. Error handling for a user changing their mind and so forth is a big effort.
There is an application that looks like it does the whole job: http://www.sigmaxim.com/Products/Inspect/inspect.html though I haven't used it.
Thank you, I will look into this
