How to cross check after IDD ??
  • June 18, 2015
  • 2 replies
  • 1986 views
I have corrected a model using IDD Is there any way to check that the model created has same topology as that of the original one !?
Message was edited by: pradeep kamble
It's difficult to tell as it depends on each case. Sometimes analytic surfaces change their topology to non-analytic, and that is why you should always freeze the specific node you work on upfront.
To see if the topology has changed i usually look at the surfaces isolines which are off by default.
pkamble1-VisitorAuthor
Thank you James
