How to do this in cocreate pe?
  • August 1, 2010
  • 2701 views
http://www.youtube.com/watch?v=zcfoc6MPsXw&feature=player_embedded
It's a car made in 3dvia shape, but I can't push/pull along the spline.
Hi Chris, I've seen that one, amazing, but not exactly for noobs, I'll look again in hi-def, thanks.
Greetings Terry, and thanks for sharing the video. To create that car in a similar fashion you would use a combination of 3D Curves (Spline) and Sweep commands. When using the 3D Curve Spline command, you will need to use the copilot planes to lock the creation of the curve into one plane (similar to how curves where made in that video). You could also use 2D spline curves if you like. If I find some free time in the coming weeks I'll post a video of how to create that car in CoCreate Modeling.
In the mean time, here is a video that shows some of the techniques you would use to create the car. This video also shows some advanced surface manipulation techniques that you won't be able to do with the free version of CoCreate Modeling.
~Chris
