How to export a model to STEP and include Masterdata fields (Part Number)?
  • May 15, 2017
  • 4 replies
  • 2561 views
I'd like to be able to export my Elements/Direct assembly to a STEP format (AP214), and include the Part Number field.  Is there a way to do this?
Hello Daley,
Exporting an assembly as a STEP (AP214) file format should take the name of your assembly and all part names within the structure browser without any special changes to the STEP configuration. Unless your structure browser does not show the same information as what your parts are numbered.
In the below two images I created a STEP export of an assembly in Creo Elements Direct and then imported that STEP file in Creo 2.0 (Parametric) and the naming of the assembly and parts is the same minus the Creo extension.
If this is not what you're seeing then maybe you can send a screen image of what your structure browser looks like for the assembly you are trying to export.
Thom
Hi Thom, thanks for your reply.  That is why I'm seeing as well, but what I am trying to get is the part bodies named with the _part numbers_ not the name.
- Elisabeth
Actually, it doesn't really have to be named with the part number field, so long as it's included as a property.  But my exported files don't seem to include any of that data.
