How to get intelligent fastener extension for Creo elements 5.0?
  • September 3, 2016
  • 3943 views
I have been trying to add fasteners in some assemblies. is there any way to assemble automatic fasteners in Creo-Elements 5.0?
The Intelligent Fastener Extension is new for Creo3, so I doubt there will be any back porting to even Cre02, let alone Creo/Elements-Parametric 5, which is out-dated and no longer supported.
thank you. Then how should we use the part library in creo elements 5.0?
The intelligent fastener extension included with Creo 3 is nothing more than a modified version of Sigmaxim's SmartLibrary bundled directly with Creo.  You can still go to Sigmaxim and purchase the full product.  This would allow you to automatically assembly fasteners as well as other library components.  They will certainly have versions that are still compatible with Wildfire 5.
