How to Have Drawing Iherit Parameters from a Format?
  • March 19, 2013
  • 21 replies
  • 11858 views
I am trying to create a Format that uses parameters to fill out the title block on our drawings. When I create a drawing, Pro prompts me for values for each parameter, but once I have entered the values, the parameters do not show up in my list of parameters for the drawing. Is there a way to get a drawing to inherit the parameters from its format?
Dale_Rosema
Michael,
Are you asking how a drawing can inherit it's parameters from the model when using template/formats?
Thanks, Dale
Yes, I am trying to get my drawings to inherit the parameters from their respective formats. This way, I can use a format, and it will bring over parameters like title, revision, and drawing number, and then I will be able to edit them within the drawing if needed. Right now, the drawing prompts me to enter values when I bring the format in, and then it prompts me again each time I create a new sheet. When I create a new sheet, I'd also like it to autofill the same values that I have already specified.
-Mike
The variables have to be placed in tables. You cannot simply place a note as the variable. Strange but true.
