how to import image into sketcher, to create offset afterwards
hello proe gurus..
I need to import an image into the sketcher in order to use it as a template to create the logo of a company.
I will later on use the sketched logo to create an offset surface.
But my main question is...how to import the image (I have available as jpeg of tiff) into the sketcher without any distortions?
The height to width relation should be maintained. I will later reduce the size of the image to fit it to the part.
thank you
al.
im using proe 3
