How to insert one drawing into other drawing with drawing format ?
  • February 8, 2018
  • 5 replies
  • 4170 views
We want to insert one supplier drawing to our standard drawing template. Supplier provided creo drawing with its dependent model and format (.frm), So i want to know, how we can import complete drawing sheet with its dependent model and format to our standard template.
Prashant Pandarkar
StephenW
I can't think of a way to do it when you include the requirement to keep their format. That would seem to be the problem.
Too make it look the same, I would import the model from the other drawing but I would use an export/import function such as DXF to bring the format information over.
If "Overlay" is still in the Drawing module in versions higher than Creo 2, try that. I am not sure how much functionality you are looking for but this might be a good compromise.
We tried with overlay command but with this it is not possible to edit or modify drawing view as per owning CAD.
-Prashant Pandarkar
Your question is ambiguous.
Do you want to have your own drawing, with your own format, displaying your supplier's completed drawing on your sheet?
Perhaps you could make a pdf or dxf of your supplier's drawing and import that into your own drawing sheet.
Or perhaps you could call out your supplier's drawing in your BOM instead?
