How to model an elliptical gear using creo v2.0
  • March 29, 2016
  • 3 replies
  • 2589 views
step by step procedure for designing and modeling an elliptical gear would be very much helpful as i didnt get any material for it , the same for spur gears are vastly available but nothing in detail are available for non circular gear,pls help
2-Explorer
March 29, 2016
Hello Kiran,
have never seen "elliptical gearing" 3D parametric model. l can share my evolvent_angular_bearing parametric model. Think the way to your model will be similar, but more complicated.
See attached file.
Regards
Milan
kbose1-VisitorAuthor
Thank you steven , I'm facing an issue on how to draw the tooth profile as you imported the tooth profile from the sketch palette.It would be very helpful if the sketch of the tooth profile is available.
Check out www.Gearotic.com
GearoticMotion3.mp4 - YouTube
