How to open .dwg file in Creo 2.0?
  • April 28, 2015
  • 2 replies
  • 2347 views
Hi I want to open a .DWG File which is made in autocad 2011. But when I open it,It give me "Invalid DWG file" message. Can you please share step by step process to open DWG File.
You can simply open the files in pro-e window. or filter the .dwg file in type. see image, After that you will see the details to open with desired criteria
Mahesh_Sharma
22-Sapphire I
January 10, 2018
"Invalid DWG file", message can appear when file is encrypted or there are contents which are not supported.
Can you share your file here?
