how to place linear point-to-point dimension?
  • January 11, 2018
  • 11 replies
  • 9431 views
Very basic question I can't figure out.  I left-click the first point and it highlights.  If I left-click the second point, it highlights but the first one is released.  If I ctrl-LMB click the second point then both the points highlight.  But now what?  How to get the preview of the dimension?  If I MMB click where I want the dimension to be placed, both highlighted points get released and no dimension is placed.
The only doc I could find on it is here:
http://support.ptc.com/help/creo/creo_sim/usascii/index.html#page/sim/simulate/sketcher/To_Create_Linear_Dimensions.html
Doing what it says but no joy.  This is Creo 4.0
Is your mouse set up to behave like a standard mouse? (In other words, might it be set up for a left-handed person, or is the middle mouse button mapped to something else?)
For creating a dimension, it is left clicks using the CTRL key, and then middle mouse button to place the dimension. Where you click the middle mouse button determines if you get a horizontal dimension, vertical dimension, or angled dimension. If you middle mouse button over an angled line between the two points, for example, you will get the dimension along that direction.
tekknow1-VisitorAuthor
Hi Dave,
Thanks for the reply and confirmation about the correct way to place a dimension.  That is exactly what I was doing but no dimension would appear.  I could see the two point clicks highlighted.  At that point there is supposed to be a ghost dimension which can be placed with a third MMB click.  I would not see the ghost dimension and when I MMB click, not only would the dimension not be placed, but the two selected points would disappear as well.
More recently, I was successful at placing a dimension.  I don't know what was different that time, it just started working.  I must have been in some mode where dimensioning doesn't work.  I'll keep my eye on it and if I happen to stumble back into that mode, I'll reply here again.
Greg
Is your dimension visibility perhaps turned off? In the In Graphics Toolbar, the third icon from the right is a drop-down for controlling the visibility of entities in the sketch. One of the check boxes is for displaying dimensions.
