How to pull out part from sub asm in assembly
  • June 18, 2014
  • 12 replies
  • 13515 views
Under main assembly ,I have subassembly which created with one part(default constraint used) like
Engine .asm (main assm)
piston.asm(sub asm)
piston ring .prt (part-under subasm piston.asm)
I want to pull out piston ring.prt from piston.asm (sub asm) & want to make it separate part direct under main asm (engine .asm ) becuse I dont want piston ring.prt place under piston.asm (sub asm).
Note:
In proe we have an option to make sub asm from individual ppart ( move to assembly option), I am looking vice versa
Dale_Rosema
Haris,
Follow this thread:
http://communities.ptc.com/message/246290#246290
I think this is what you are asking about.
Thanks, Dale
Thanks for your reply.
But , that conversation not satisfied my question.
Will restructure option help me to pull out part from sub asm & individual become part under main asm?
Mahesh_Sharma
22-Sapphire I
June 18, 2014
Haris,
Restructure option as in thread given by Dale will help you. Using restructure you can select the components and define target assembly.
Quite honestly, I would see if the carburetor has dependencies... I just move it down until it is at the end. You know which object has a dependency because you cannot move the assembly below it. Resolve the dependency and continue to move the assembly down.
Then add a new carburetor and delete the assembly. I find the re-route routing a painful one when it comes to guessing what it really wants.
That's the problem. It has a bazillion dependencies. I was trying to avoid all the rerouting and re-defining. It seems like it would be easy for PTC to just make the "insert here" functionality work when trying to pull a sub-assembled part into it's parent assembly. It just doesn't make sense why it HAS to try to put it at the very end of the parent assembly when re-structuring.
