How to restore assembly shading back to part default?
  • February 17, 2012
  • 1062 views
Hi Gurus - ive been bashing my head on this one for a while, when in assembly and in shaded view the menu give you the options to see the part in wire frame, hidden wire frame, solid wire frame, shaded and transparent.
After picking a Thanks
Columbia Plastics Ltd
Surrey, B.C.
604 530 9990 Ext 236
GaryPitt10-MarbleAuthor
Wow - 3 come backs within 2 mins, thanks.
1. Open the View Manager > Style > double click on the style name that has
the + after it.
2 Maybe you could go to the Style tab in the view manager and create a style
where the part is not transparent. I know this sucks, but it might be a work
around.
3 Go to "View", "View Manager", "Style" tab. Choose "Default_Style", and
then choose "Master Style" (or you can right click on "Master Style" and
choose "Set Active".) Basically you want to discard the style changes you
made.
Thanks guru's
Gary Pitt
19320-60th Ave
Surrey, B.C.
V3S 8E5
_____
