2-Explorer
July 10, 2014
how to select a sub-assembly on screen
  • July 10, 2014
  • 2 replies
  • 1111 views
Hi all,
I do like the smart filter - but it is far from perfect. You would think that in an assembly environment the smart filter would start with sub-assy's and then part>feature>geometry...
Is there an easy way to select a sub-assy by picking on the screen?
-Nate
Best answer by rohit_rajan
try this:
select a part from the sub-assembly on screen then RMB...the last option i guess is "select parent"..that should select the sub-assembly.
try this:
nrollins2-ExplorerAuthor
2-Explorer
July 10, 2014
wow - thanks. I am ashamed that I did not find that - live and learn.
