how to set drawing view : view Display style ?
  • September 24, 2016
  • 1642 views
Following is the code, through which I am setting the needed view display style, which is working fine in the code, no error as well..... but still in drawing view no changes. Can anybody answer this???
Public Sub listViews(ByRef session As IpfcBaseSession, ByVal fileName As String)
        'Dim file As StreamWriter = Nothing
        Dim model As IpfcModel
        Dim drawing As IpfcDrawing
        Dim view2Ds As IpfcView2Ds
        Dim i As Integer
        Dim view2D As IpfcView2D
        Dim viewName As String
        Dim sheetNo As Integer
        Dim solid As IpfcModel
        Dim solidDesc As IpfcModelDescriptor
        Dim outline As CpfcOutline3D
        Dim scale As Double
        Dim viewDisplay As IpfcViewDisplay
        Dim displayStyle As String
        Dim selection As IpfcSelection = Nothing
        Dim selectFeaturesView As IpfcView2D
        Try
            'Create file to store information to be displayed
            'file = New StreamWriter(fileName)
            'file.WriteLine("<html><head></head><body>")
            'Get current model and check that it is a drawing
            model = session.CurrentModel
            If model Is Nothing Then
                Throw New Exception("Model not present")
            End If
            If Not model.Type = EpfcModelType.EpfcMDL_DRAWING Then
                Throw New Exception("Model is not drawing")
            End If
            drawing = CType(model, IpfcDrawing)
            view2Ds = drawing.List2DViews
            For i = 0 To view2Ds.Count - 1
                'Get information about each view such as name, model
                view2D = view2Ds.Item(i)
                'selection.Insert(0, view2Ds.Item(i))
                viewName = view2D.Name
                sheetNo = view2D.GetSheetNumber
                solid = view2D.GetModel
                solidDesc = solid.Descr
                outline = view2D.Outline
                scale = view2D.Scale
                viewDisplay = view2D.Display
                view2D.Display.Style = EpfcDisplayStyle.EpfcDISPSTYLE_NO_HIDDEN
                viewDisplay.TangentStyle = EpfcTangentEdgeDisplayStyle.EpfcTANEDGE_DIMMED
                Select Case viewDisplay.Style
                    Case EpfcDisplayStyle.EpfcDISPSTYLE_DEFAULT
                        displayStyle = "default"
                    Case EpfcDisplayStyle.EpfcDISPSTYLE_HIDDEN_LINE
                        displayStyle = "hidden line"
                    Case EpfcDisplayStyle.EpfcDISPSTYLE_NO_HIDDEN
                        displayStyle = "no hidden"
                    Case EpfcDisplayStyle.EpfcDISPSTYLE_SHADED
                        displayStyle = "shaded"
                    Case EpfcDisplayStyle.EpfcDISPSTYLE_WIREFRAME
                        displayStyle = "wireframe"
                End Select
                view2D.Regenerate()
            Next
        Catch ex As Exception
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
        Finally
            'If Not file Is Nothing Then
            '    file.Close()
            'End If
        End Try
    End Sub
I've done this to make the view display style update.
Dim newdisplay As IpfcViewDisplay
newdisplay = view2D.Display
newdisplay.Style = EpfcDisplayStyle.EpfcDISPSTYLE_NO_HIDDEN
view2D..Display = newdisplay
view2D.Regenerate()
