11-Garnet
August 10, 2011
How to suppress all failures on one click
  • August 10, 2011
  • 4 replies
  • 2855 views
Hi friends,
I have a large assembly with failures in some sub-assemblies and parts.
Whenever I open this top-level assembly a failure window keeps on appearing for each and every failure.
I just want to know if there is a possibility so that I can suppress all the failures once instead of doing it again and again.
I hope my doubt is clear to you all.
Pl help.
Thanks in advance...
What version of WF are you using? WF5 has an improved failure mode that could solve your problem.
11-Garnet
August 11, 2011
Hi Matt,
Im using WF5..
WF5 has better failure handling but it seems you have old type of handling chosen as default not new one. Check your config.pro for this or find it in options.
