how to switch over to different templates in schematics?
  • September 16, 2014
  • 3 replies
  • 1755 views
Hi Team,
where Can I check which template used for that design and how to switch over the templates?
Madhu
Best answer by JimBarrettSmith
The tool will only show you formats that the sheet content will fit in.
As an alternative create a new sheet with the template you want and use the move to sheet tool
To select a different drawing template/ format in the diagramming ribbon click "Change Sheet format" and selet your new drawing template
msonnathi1-VisitorAuthor
I checked that option, it shwoing only limited options. is any alternative?
