how to use a library linestock
  • November 14, 2011
  • 1810 views
Users,
How do you use a linestock from your library when routing a pipe in WF5 M050? I have “pro_pip_lnstk_dir” set to the correct folder, but I can’t find an option to browse for a linestock. I get the create box every time.
Best answer by ArnoldCollett
I found it. While in the Piping Application; Edit menu, Setup, Line Stock, then in the side menu Read and select desired linestock.
ArnoldCollett12-AmethystAuthorAnswer
