How to use the function ProSurfaceTessellationGet
  • September 9, 2016
  • 2 replies
  • 1371 views
My program is as follow:
ProSurfaceInit(owner,model_item.id,&surface);
ProSurfacetessellationinputAlloc(&input);
ProSurfacetessellationinputStepsizeSet(input,0.02);
ProSurfacetessellationinputChordheightSet(input,0.01);
ProSurfacetessellationinputAnglecontrolSet(input,0.0);
ProSurfacetessellationinputUvprojectionSet(input,PRO_SRFTESS_DEFAULT_PROJECTION,NULL);
ProSurfaceTessellationGet(surface,input,&tessellation);
ProTessellationVerticesGet(tessellation, &p_points);
when the program go on the function ProSurfaceTessellationGet ,there is something wrong,PRO_TK_GENERAL_ERROR,‌see the online help ,it means The function could not generate the tessellation for the input surface.
it bothers me for several days,so I really really need someone's help.
FV_01
September 9, 2016
Hello all,
Meng, I would do something like this to pinpoint angle and chord values:
double step = 0.02; //???
ProSurfacetessellationinputStepsizeSet(input,step);
double chord = 0.01;
double angle = 0.25;
ProSurfacetessellationinputChordheightSet(input,chord);
ProSurfacetessellationinputAnglecontrolSet(input,angel);
int iterations = 20;
ProBoolean success = PRO_B_FALSE;
for ( int i = 0; i < iterations; ++i ) {
if( PRO_TK_NO_ERROR == ProSurfaceTessellationGet(surface,input,&tessellation)){
success == PRO_B_TRUE;
break;
chord *= 2.0;
angle *= 2.0;
if( PRO_B_TRUE == success)
HIH.
Feliks.
mlee-91-VisitorAuthor
hello Feliks,
     Thank you for your advice. and I have  been tried  debug as your way,I understand your method is very effective to improve the accuracy of tessellation. but there are still other problems,maybe something I mistake. I'll try it again.
     I have another question ,the parameter of the SurfaceTessellationInput how to affect the type of surface? I have tried to set the Stepsize and chordheight to match the different type of surface e.g. the plane the spherical etc.but my program occurs debugging fault.
    If I do in  sample way, it could be success,but the function ProSurfaceTessellationGet always be PRO_TK_GENERAL_ERROR,can you tell me why?
