i am not able to find ptc schematics 3.0 and from where i will get fittings in piping....as i want to learn piping.....plz help
  • February 6, 2016
  • 2 replies
  • 1717 views
plz someone help me to find fitting for piping and also schematics 3.0 as i m a college student ....beginner in ptc creo 3.0. when i click on insert fitting option...it shows option end...etc...but did not show any fitting..plz help me
Piping, Cabling & Schematics
2-Explorer
February 8, 2016
Creo Schematics is an extra installation (not on the same disk/image as Creo Parametric). I don't know, whether a Student Edition exists for it.
In a commercial installation there are some example fitting under Creo 3.0\<datecode>\Common Files\text\piping_data\fittinglib
They are actually meant for spec-driven piping, but should work for manually inserting with non-spec-driven piping as well.
Hope this helps you a bit!
pdayal1-VisitorAuthor
thanks sir....now i  can access them in spec-driven piping.
