I cant get my balloons quantity divided properly and I also cant create balloons
  • August 4, 2015
  • 0 replies
  • 682 views
I am currently making a drawing of an assembly and I am having a few problems. and i was wondering if you guys can help.
problem 1.
I am using a quantity split circle for my Bom Balloons. however i broke my over all assembly into parts and it is divided into sheet 1 2 and 3, and all 3 sheets share the same parts. but I cant use the "split balloons" to divide the quantity between sheets. how should i do it ?
problem 2.
I am trying to give a part in the drawing a balloon. the part is listed on my table but every time i click on create balloons by component and click on the part, nothing comes up and i see a message that says
"one or more BOM balloons corresponding to this table are erased. Use unerase from the drawing tree to display erased BOM balloons."
and I cant seem to fix that and have my balloon show.
can you help?
Thank you!
