Aug 30, 2026 11:08 PM UTC
I have saved a copy of a assembly model using save a copy under file in Creo.
I want to break the links in the model so I can delete parts in the copy of the model I saved. How do you do this?
If I can’t break the links, when I reopen the copy where I have previously deleted parts regenerating errors occur with regenerating message stating x number of missing model
der_Wolfgang
Aug 31, 2026 9:31 AM UTC
Those Things DO NO HAPPEN in Creo Elements/Direct Modeling - one more TIME WRONG forum used!
BTW you dont have those kind of dependencies in Creo Elements/Direct Modeling: it is more easy to use.
May be you might wanna ask your question in a more matching forum like:  https://community.ptc.com/t5/Creo-and-Creo-Parametric/ct-p/creoparametric
Creo Parametric should not be confused with Creo Elements/Direct Modeling, formerly named CoCreate SolidDesigner CAD Products.  You posted your question in the section for Creo Elements/Direct Modeling section.. The chance of getting helpful answers is better using an appropriate forum/section!
● cad.de + osd.cad.de ● java-forum-stuttgart.de + jugs.de ● notepad-plus-plus.org ●
