I need help on customizing view displays
  • June 15, 2017
  • 0 replies
  • 1045 views
Hi ,
Is this possible to customize the view display in creo 2.0, if possible means
can any one suggest the solution
I have some of foam drawing which was modeled in Surface model technique
In drawing i need to show the exact boundaries and textures of those foams
But it is not possible to show on the standard view displays. Currently i am showing
those lines with edge display option. but it takes lot of time to regenerate. and a irritation work
Can any body suggest easy way to do that
Mohan.V
