I need model air pipes
Hi all,
I'm new user in managing modules like piping or cabling, so I prefer ask to people with more experience.
I need to model air pipes like SMC or FESTO components, specially air pipes.
SInce now I've do this with the "pipe" feature:
1)Insert > Advanced > pipe... Hollow
2)multiple rad
3)choose external diameter and thick
4) spline, add points.
So I needed a set of points to make the path of the spline. I inserted them with an offset to coordinate system, moving them by hand and by sight to let the pipe doesn't hurt the rest of components.
All of this is not much comfortable and the pipe doesn't follow a path made by straight lines because the spline has a different trajectory. however make it with a standard feature would require much time and some external references, and I want avoid this.
Is Piping or cabling module one right way to do what I need?
Regards
