IF Diameter SUMMARY
  • April 30, 2013
  • 0 replies
  • 412 views
Summary of "IF Diameter":
Neat ideas suggested. However - could not get any to work globally.
Responses:
Can be done via JLink (or toolkit). You can also do a search for all
dimensions with 5.18 as a nominal value.
That eliminates the need to pick on the features one by one. But you
still have to change them one by one (but
they would be right there in front of you).
Exact syntax for one diameter is this (replace DIAMETER with the
dimension name):
IF DIAMETER == 5.18
DIAMETER = 5.00
ENDIF
Pro/Program, find/replace
Replace DIAMETER with the parameter that is originally driving the
diameter dimension.
IF p254 == 5.18
P254=5.00
You could try using Edit Program, which opens in a text editor, and
replace 5.18 with 5.00. If there are no
dimensions at 5.18 that you want to preserve, just to a mass replace.
In Creo2 it's:
Tools > Model Intent > Program > Edit Design
(Warning, if it's an assembly, you'll need Advanced Assembly to use
this.)
Could you edit the model's Program, then do a Find/Replace on the
dimensions, and then apply the changes to the
model when finished editing?
