Iges file used surface extraction process without import file reference how to create solidify part
  • May 24, 2017
  • 4 replies
  • 1838 views
I want to create solidify surface by used import file of plastic interior part.
Mahesh_Sharma
22-Sapphire I
May 24, 2017
Pratap,
Explain this in detail.
There is Import Data Doctor (IDD).
You can modify the definition of the import part and manipulate it.
It is not easy and it is not a magic bullet.
It just lets you manipulate the surface geometry.
Pratap,
Attached is a PDF and sample file I use with my Creo college students.  It explains how to work with Import Data Doctor (IDD), specifically with Creo 3.0.  If you are using a different release of Creo you may, or may not need to adjust for changes in the menu
Hope this helps
pshinde-31-VisitorAuthor
I have one IGES format Plastic interior component "A' style surface so, I want to create into parametric model. it means B offsetting surface ( For certain Thickness) and 'C' closed surface and solidify so, How can I used Import file and create the part without the import date reference.
