Incorrect Mass
  • June 10, 2014
  • 2 replies
  • 1335 views
WF4, M220
This is driving me crazy, I cannot figure out what is wrong.
I have a very small part that is built in inches (Proe default inch lbm Second units) but I want to report the mass in grams.  Proe, however, will not calculate the proper mass.
The setup:
I've set my relations as units sensitive.
I have a SPECIFIC_GRAVITY parameter defined with its units set as g/cm^3, and I have the relation "MP_DENSITY=SPECIFIC_GRAVITY" to set my density from the SPECIFIC_GRAVITY parameter.
I have a "WEIGHT_G" parameter defined with its units set to g.  In my post regen relations I have "weight_g = pro_mp_mass"
I have a "WEIGHT_G_man" parameter defined with no unit.  In my post regen relations I have "weight_g_man = pro_mp_mass*453.592" (default conversion factor for pounds to grams)
No geom check in the part, no alternate mass defined.
The results:
Proe shows the part volume as 0.003302 in^3.
Proe shows the part weight (lbm) as 0.000132.
Proe shows the value of WEIGHT_G as .000132 also, which is obviously incorrect.
Proe shows the value of weight_g_man as 0.060068, which is correct.
The question:
I cannot for the life of me figure out why the value of WEIGHT_G is incorrect.  I've used unit driven relations in the past and they've worked fine.  To my eyes, everything is set up correctly.
What can I do to fix this (aside from giving up and simply using the manually calculated parameter)?
Isn'tthat the old hidden PTC sillyness of needing to "generate report"to get the mass props calulation to show up in other areas?
I don't think so.  I've got mass props set to calculate automatically and I'm getting values for the standard MP parameters.
I even created an MP analysis feature in the part and drove my relations off of it instead.  Same result.
