Indexed machining, how?
  • July 10, 2012
  • 3 replies
  • 2235 views
Hello, i would like to know which CAM-technique are people using for indexing machining (3+2). I want to get machining code, where the output coordinates are related to different CSYS, not to a unique CSYS.
See attached image. It shows a simple part with holes in two different planes with 2 CSYS (X,Y,Z and X1,Y1,Z1). Sometimes happens that CAM generated programs must be modified by the machine operator. For example, you need to change drilling coordinates.
The code we want is something like this:
(CSYS XYZ)
DRILLING CYCLE
X12.5 Y25
X12.5 Y50
(CSYS X1Y1Z1)
DRILLING CYCLE
X15 Y15
X55
Y40
X15
Imagine the operator needs to change drilling coordinates of the inclined plane (from X15 Y15 to X16 Y16). It would be difficult to change if all coordinates are from a single CSYS (XYZ). What would be the appropriate way of working with Creo/NC:
- Should I create different operations for each setup (plane) or
- Should I create different sequences setting local CSYS for that sequence
Is this a task for the postprocessor?
How are you doing this?
Best answer by OlivierCOUPAT
Hello Javier
For his job, you need to create several Csys for each plane in the same operation.
Then, in each sequence, you need to pick the correct Csys and set the parameter:
COORDINATE_OUTPUT SEQUENCE_CSYS.
This will ouput the motions in your Csys offset.
This offset appears in the TRANS function in the ncl file
LOADTL / 1017, LENGTH, 80.00000
$$-> CUTTER / 6.000000
SET / OFSETL, 55
$$-> TRANS / 0.0000000000, 16.5000000000, 0.0000000000
$$-> CSYS / 0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000, $
-0.5000000000, 0.0000000000, 0.8660254038, 0.0000000000, $
0.8660254038, 0.0000000000, 0.5000000000
In the post, it will depend the way the operator will work in the machine.
- if he wants to set all the Csys manually in the Workoffset (i.e. G54...G59) then you will not have a lot of work to do in the post. You can use the parameter FIX_OFFSET_REG to set the correct workoffset register. It will ouput a SET/OFFSET,.. function in the ncl file and normally a G54..G59 code in the tape file.
- if he wants to see the offset in the tape file (i.e. G52X Y Z for fanuc), then the post needs to handle the TRANS/ function in the ncl file to output the correct offset value in the tape file
Hope this helps you
Olivier
Hello Javier
SET / OFSETL, 55
Hope this helps you
Olivier
Hi Olivier, i tried some of the settings you are talking about but I need some work on the post.
Thank you!
