Inheritance feature layer rules
  • September 18, 2018
  • 7 replies
  • 4592 views
In Creo 4.0 I have a base part  with an inheritance feature of another part.
In the base part I have default layers to place features on according to their type. So in the base part I have a layer for quilts and a layer for datums. The inherited part also contains features of the type datum and quilt (on the same default layers with the same names as in the base part).
I can show/hide the inheritance feature as a whole with all the features it contains, but I want to be able to show/hide ONLY features of a specific type by using layers. For example I want to be able to separately show/hide the quilts belonging to the inheritance feature and the quilts belonging to the base part by placing them on separate layers.
I have not gotten this to work using layer rules, but I'm certainly not an expert on the subject. So any help on if and how this is possible is appreciated. Many thanks in advance!
Wouter
There are multiple levels of items at work here and what "level" the thing you are adding to a layer lives on comes into play.
For a datum plane, there's the plane itself with lives inside the datum plane feature.  A sketch feature contains multiple sketch entities.  The inheritance feature contains dozens of individual entities.
Once you hide an upper level item, nothing inside it can be made visible.  The hidden status of the upper level overrides any settings on the lower level items.  So, if you hide a sketch feature you cannot make any individual sketch entities. Because of this all my rules put entire features on layers rather than individual entities.  (Quilts are an odd case, they are neither parent or child in this scenario. I don't put them on layers, only the surface features themselves.)
With an inheritance, in the source part you may have put the features on layers but once they are inherited into another part they become entities of the inheritance.  That makes it difficult to control them, as you've found.
A couple of things that are helpful.
  1. Put features only on layers, not entities.
  2. Use Isolate to show items instead of hide.  If a feature is on two layers, one hidden and one shown, it'll be hidden.  If one's hidden and one's isolated, it'll be visible.  Hide beats unhide, isolate beats hide.  (There is a new status in Creo 4 that I'm not familiar with.  I'm not sure how that affects things.
The situation you are dealing with is still challenging and I've spend a lot of time (too much time, frankly) thinking about layers.
Sorry I don't have better news.
Thank you very much for your reply. The tip about features becoming entities of the inheritance feature helps a lot. It's actually quite logical, but I didn't think about it. I think it's probably the reason why I couldn't get rules to work the way I want. I do always put features only on layers, not entities, because that would make layer control much more difficult.
I will try again but this time with filtering based on entities instead of features and let you know if I have found a way.
BTW: The new status in Creo 4 is actually pretty good. It allows to put features on an 'shown' layer in addition to the 'hidden' layer that was present in previous versions of Creo. I do not use it to save as a status for 'finished' parts (I only use clearly named and defined layers), but use it a lot when working on parts. It makes it easy to show just the features I currently need shown to work on the part without other features cluttering my view . The model tree icons also reflect the layer status much better now.
I haven't played with Creo 4 enough to understand the new layer options, does "isolate" still exist in addition to "hidden", "unhidden" and the new "shown"?  I'm wondering if shown is isolated renamed or something new.
