Insert all instances of a part into an assembly
  • September 8, 2016
  • 6 replies
  • 2965 views
Is there an automatic way to assemble all instances of a specific part into an assembly?
Thanks in advance!
Do you mean for instance 8 screws into 8 holes?
Or do you mean all instances of a family table into an assembly?
September 9, 2016
All instances of a family table into an assembly.
As Dan says I think you have to assemble each one individually which is a bit of a drag if the are a number of instances. I am curious as to why you want to load all the instances of a family table into an assembly?
I assume that you want all of the instances to be assembled in the same position using the same constraints. If so, make a family table of your assembly with instances having each of the part instances in them. That would give you a different assembly model for each of the part instances. If you want all of the instances in one assembly, the only way I know of doing that is to assemble each of them.
