Inserting a New P-Clip into an Existing Routed Cable
Wildfire 4.0, Pro/Cabling.
I have a routed cable, going from an entry port on one connector to the entry port on another connector, via a couple of p-clips (routed 'Along Axis'). Now I want to insert another P-Clip. How do I do that? The only solution I have so far found is to delete the cable and start routing it again! I'm sure there is a better way...
Whilst on the subject, does every connector have to have a different part name? I found that, once I had designated an entry port on the first connector '15_w_d_type', I could not then choose the second connector '15_w_d_type' entry port for the other end of the cable. It was fine if the second connector was called '15_w_d_type_2'. That doesn't sound right, either. I can surely use the same standard part at each end of a cable.
The documentation on this subject, as you will be aware, is a little sparse. I can find a number of tutorials that get me as far as I have got, but any modifications and more adventurous stuff - not much seems available. Unless you know different!
Cheers,
John
